Resolved Eggy Generator
Will Eggy Generator work with GD Library aswell or had to be PHP Imagick/ImageMagick? thanks
At present, Eggy Generator requires PHP Imagick/ImageMagick. GD Library on its own isn't currently supported, as some of the Generator's rendering features rely specifically on Imagick.
If your host supports ImageMagick, you'll just need to make sure the PHP Imagick extension is enabled for the PHP version your XenForo installation is using.
I have contacted my hosting provider but on my hosting contract not supporting the ImageMagick but supports GD Library :(
Unfortunately, if your host can’t provide Imagick/ImageMagick, Eggy Generator won’t be able to run on that hosting package as it stands.
The only real options would be moving to hosting that supports Imagick, or if that isn’t practical, I can arrange a refund for Eggy Generator. :-(
Don't worry i haven't purchased it yet . I was just double cheeking before i buy the add-on , many thanks any way .
