- 179
Connecting With AdiIRC
AdiIRC supports a connection command similar to mIRC.
Use the command shown in the Eggy BNC dashboard:
Replace the placeholders with your own account information.
Saved connection settings
A saved AdiIRC network entry should use:
Multiple networks
Create a separate saved entry for each dashboard network.
For example:
The server and port stay the same.
The network name inside the password changes.
Common AdiIRC problems
Check for:
/server -m bnc.eggy.net +5000 Username/Network:<password>
Server: bnc.eggy.net
Password: Username/Network:Password
Multiple networks
For example:
Eggy BNC Libera
Eggy BNC DALnet
Eggy BNC OFTC
Check for:
- TLS being disabled.
- Plain port 5000 being used without SSL.
- An incorrect dashboard network name.
- A saved password from before an account password change.
- Spaces accidentally copied into the password field.
