Resolved Installing Pool Expansion Hub & AI Opponent
I installed the latest version of Eggy Pool, which is 1.0.8.
It won't let me install the Expansion Hub or the AI Opponent extras, as it's giving me this error:
Could not process Eggy-Pool-Expansion-Hub-1.0.3.zip: The following requirements for Eggy Pool: Expansion Hub were not met: Eggy Pool: Expansion Hub requires Eggy Pool 1.0.7+.
I uninstalled the latest version of Eggy Pool and then installed the 1.0.7 instead, seeing if that solves it. Gave me the same error though.
Hey there and thank you for reporting this. I will now look into this!
Thanks for the extra detail.
I’m going to send you a DM shortly with one-off versions of the Expansion Hub and AI Opponent that remove the Eggy Pool 1.0.7+ minimum-version requirement.
This is being done specifically for your installation, as nobody else has reported this issue. I’ve also been able to upgrade Eggy Pool through 1.0.7 to 1.0.8 with all of the extensions upgrading successfully throughout that process.
What makes this more unusual is that you previously experienced a very similar issue with Eggy RPG, and again you appeared to be the only person affected in that area.
That points more towards something specific to your XenForo installation rather than the Pool add-ons themselves. Possible causes could include stale add-on metadata or cache, XenForo not reporting the installed base add-on version correctly during dependency checks, or another installed add-on interfering with XenForo’s add-on requirement handling.
Rather than make you troubleshoot that side of things, I’ll provide you with one-off packages that simply require Eggy Pool to be installed, without enforcing the 1.0.7+ version check.
I’ll send those over shortly by DM.
Based on your response, I went ahead and disabled the Add-on Update Notifier add-on and they were able to be installed. I assume that means no other client you've had is using it so far, but this is an add-on that is being used by a lot of people in the XF community. That add-on is so popular that it's supposedly going to be a default feature of XF 2.4.
Based on your response, I went ahead and disabled the Add-on Update Notifier add-on and they were able to be installed. I assume that means no other client you've had is using it so far, but this is an add-on that is being used by a lot of people in the XF community. That add-on is so popular it's supposedly going to be a default feature of XF 2.4.
That may well explain why you were the only person running into this.
At the moment, there are no plans to build Eggy add-ons around the behaviour of third-party add-ons. They will continue to be built and tested against XenForo itself unless this becomes something a larger portion of the customer base is actually affected by.
I’ve also checked the Add-on Update Notifier resource you mentioned, and it is currently marked as Unmaintained on XenForo.com, with its last update dating back to December 2024. Because of that, I’m not going to make compatibility changes to Eggy products specifically around that add-on.
As things stand, you are still the only customer who has reported this particular issue. Given that disabling Add-on Update Notifier allowed both the Expansion Hub and AI Opponent to install normally, that strongly indicates the issue is being caused by an interaction with that third-party add-on rather than Eggy Pool itself.
It would also explain why I have been able to upgrade Eggy Pool through 1.0.7 to 1.0.8 with all extensions upgrading successfully, and why no other customers have reported the same dependency problem.
If XenForo 2.4 eventually includes similar functionality natively, that would be handled as part of supporting XenForo 2.4 itself. That is separate from supporting the behaviour of an unmaintained third-party add-on today.
Since you have now been able to install the Expansion Hub and AI Opponent successfully by briefly disabling that add-on, there is no need for me to send over any modified files.
Glad you’ve got it sorted now.
